[IOS-XRv ASR9000v] How to send correct SNMPv3 Informs (AuthPriv mode)?
VincentVlk82
Beginner
Beginner
Hi Community,
before deployment, we are testing SNMPv3 Informs notifications in AuthPriv mode.
Tests with IOS, IOS-XE and NX-OS were successful.
Unfortunately, configuration in IOS-XRv (Version 7.2.1) is not working correctly. Probably an configuration error.
This is the IOS-XRv config (with all parameters same for all tested platforms):
snmp-server engineID remote [redacted-IP] 80:00:1f:88:04:56:6e:65:74:5a:61:62 udp-port 162
snmp-server vrf default
    host [redacted-IP] informs version 3 priv zabbixtrap
snmp-server user zabbixtrap TESTgroup remote [redacted-IP] v3 auth sha encrypted [redacted-AUTH] priv aes 128 encrypted [redacted-PRIV]
snmp-server view ViewDefault iso included
snmp-server group TESTgroup v3 priv notify ViewDefault
snmp-server traps snmp linkup
snmp-server traps snmp linkdown
snmp-server traps snmp coldstart
snmp-server traps snmp warmstart
snmp-server traps system
snmp-server traps fru-ctrl
snmp-server ifindex persist
snmp-server mibs cbqosmib persist
With issued # debug snmp packets this is the output:
ifmgr[296]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/0/0/3, changed state to Administratively Down
snmpd[1003]: t9159 snmp_get_table_id_from_vrfid: TableID 0xE0000000 VrfID 0x60000000
snmpd[1003]: t9159 Successfully got vrf_id:1610612736 and table_id:-536870912 for vrf:default
snmpd[1003]: t9159 snmp_is_dst_address_reachable:Successfully got src address:10.201.254.253 to dest:10.201.254.253 in vrf:default, vrf_id:1610612736, ifhandle:0x1000018
snmpd[1003]: t9159 Src address updated as :10.201.254.253
snmpd[1003]: t9159 snmp_send_pdu_udp_transport: Q-ing INFORM[sp 162, dp 41472]
snmpd[1003]: t9187 SENT[I] 81 bytes to [redacted-IP]:162 from 10.201.254.253:162, vrfid 0x60000000, tblid 0xe0000000
snmpd[1003]: t9178 RECV Inform response  114 bytes from [redacted-IP]:162 to 10.201.254.253, vrfid 0x60000000, tblid 0xe0000000
snmpd[1003]: t9178 snmp_get_inform_response_id: SrParseSnmpMessage error_code = 602
snmpd[1003]: t9178 ERROR: Inform response pdu type -168 request-id 183 error_status = 0 error_index = 0
After the Timeout period, this packet exchange is repeated according to "Inform Retries" count integer.
I'm also attaching screens from WireShark captures of sent and received packets between router-VM and NMS (Zabbix NMS with Net-SNMP's snmptrapd)
Sent SNMPv3 packet (from IOS-XRv):
Received SNMPv3 packet (from snmptrapd):
For examples and comparison, this vIOS configuration worked as expected:
snmp-server engineID remote [redacted-IP] 80001f8804566e65745a6162
snmp-server user zabbixtrap TESTgroup remote [redacted-IP] v3 auth sha [redacted-AUTH] priv aes 128 [redacted-PRIV]
snmp-server enable traps snmp linkdown linkup coldstart warmstart
snmp-server inform
snmp-server host [redacted-IP] informs version 3 priv zabbixtrap
Also working CSR1000v (IOS-XE) example config:
snmp-server engineID remote [redacted-IP] 80001F8804566E65745A6162
snmp-server inform
snmp ifmib ifindex persist
For comparison, I'm attaching working SNMPv3 Inform packet exchange:
Sent SNMPv3 packet (from vIOS):
Thank you for your time and attention. Of course, I'm open for further questions. Any help or direction would be much appreciated.
Best Regards,
Vincent Vlk
The content of this message was removed
Recognize Your Peers
