IOSXE-3-PLATFORM
HaYaDa
I have the following syslog message: IOSXE-3-PLATFORM
I have already searched through all the system and error message guides for IOS 17.x.x and 16.12.x but have not found a match.
I would be very grateful if someone could tell me where to look, or where I can find the corresponding system message guide or error message guide.
Thank you in advance.
marce1000
 - The particular message seems to have been 'cut off' ; do you have the full sentence including this message too ?
 M.
Many thanks for your reply... The full sentence/sentences looks like this:
%IOSXE-3-PLATFORM: 1 process kernel: ERROR L2C_TADX_INT(0)[L2DSBE]: Data Single-Bit Error,2023-05-13 11:59:03+00:00,06065e-s01-f09.net.customer.de,108,2023-05-13 09:59:02+00:00,,IOSXE,3,PLATFORM,1 process kernel: ERROR L2C_TADX_INT(0)[L2DSBE]: Data Single-Bit Error
%IOSXE-3-PLATFORM: 1 process kernel: ERROR CVMX_L2C_ERR_TDT: 0x401c0000001b0d02,2023-05-13 11:59:03+00:00,06065e-s01-f09.net.customer.de,109,2023-05-13 09:59:02+00:00,,IOSXE,3,PLATFORM,1 process kernel: ERROR CVMX_L2C_ERR_TDT: 0x401c0000001b0d02
%IOSXE-3-PLATFORM: 1 process kernel: ERROR L2C_TADX_INT(0)[VBFSBE]: VBF Single-Bit Error,2023-05-04 14:55:38+00:00,03084d50-s03-f08.net.customer.de,339,2023-05-04 12:55:37+00:00,,IOSXE,3,PLATFORM,1 process kernel: ERROR L2C_TADX_INT(0)[VBFSBE]: VBF Single-Bit Error
%IOSXE-3-PLATFORM: 1 process kernel: ERROR CVMX_L2C_ERR_VBF: 0x108c000000000000,2023-05-04 14:55:38+00:00,03084d50-s03-f08.net.customer.de,340,2023-05-04 12:55:37+00:00,,IOSXE,3,PLATFORM,1 process kernel: ERROR CVMX_L2C_ERR_VBF: 0x108c000000000000
%IOSXE-3-PLATFORM: 1 process kernel: ERROR LMC0 ECC: sec_err:2 ded_err:0,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066305,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: ERROR LMC0 ECC: sec_err:2 ded_err:0
%IOSXE-3-PLATFORM: 1 process kernel: LMC0 ECC:^IFailing dimm: 0,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066306,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: LMC0 ECC:^IFailing dimm: 0
%IOSXE-3-PLATFORM: 1 process kernel: LMC0 ECC:^IFailing rank: 0,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066307,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: LMC0 ECC:^IFailing rank: 0
%IOSXE-3-PLATFORM: 1 process kernel: LMC0 ECC:^IFailing bank: 5,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066308,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: LMC0 ECC:^IFailing bank: 5
%IOSXE-3-PLATFORM: 1 process kernel: LMC0 ECC:^IFailing row: 0xa980,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066309,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: LMC0 ECC:^IFailing row: 0xa980
%IOSXE-3-PLATFORM: 1 process kernel: LMC0 ECC:^IFailing column: 0x18,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066310,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: LMC0 ECC:^IFailing column: 0x18
%IOSXE-3-PLATFORM: 1 process kernel: LMC0 ECC:^Isyndrome: 0xab,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066311,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: LMC0 ECC:^Isyndrome: 0xab
%IOSXE-3-PLATFORM: 1 process kernel: Failing Address: 0x00000000a98006c8,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066312,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: Failing Address: 0x00000000a98006c8
%IOSXE-3-PLATFORM: 1 process kernel: ERROR LMC0 ECC: sec_err:2 ded_err:0,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066313,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: ERROR LMC0 ECC: sec_err:2 ded_err:0
%IOSXE-3-PLATFORM: 1 process kernel: LMC0 ECC:^IFailing dimm: 0,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066314,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: LMC0 ECC:^IFailing dimm: 0
%IOSXE-3-PLATFORM: 1 process kernel: LMC0 ECC:^IFailing rank: 0,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066315,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: LMC0 ECC:^IFailing rank: 0
%IOSXE-3-PLATFORM: 1 process kernel: LMC0 ECC:^IFailing bank: 5,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066316,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: LMC0 ECC:^IFailing bank: 5
%IOSXE-3-PLATFORM: 1 process kernel: LMC0 ECC:^IFailing row: 0xa980,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066317,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: LMC0 ECC:^IFailing row: 0xa980
%IOSXE-3-PLATFORM: 1 process kernel: LMC0 ECC:^IFailing column: 0x18,2023-01-13 01:50:48+00:00,02063e43-s01-f09.net.customer.de,18066318,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: LMC0 ECC:^IFailing column: 0x18
%IOSXE-3-PLATFORM: 1 process kernel: LMC0 ECC:^Isyndrome: 0xab,2023-01-13 01:50:49+00:00,02063e43-s01-f09.net.customer.de,18066319,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: LMC0 ECC:^Isyndrome: 0xab
%IOSXE-3-PLATFORM: 1 process kernel: Failing Address: 0x00000000a98006c8,2023-01-13 01:50:49+00:00,02063e43-s01-f09.net.customer.de,18066320,2023-01-13 00:50:48+00:00,,IOSXE,3,PLATFORM,1 process kernel: Failing Address: 0x00000000a98006c8
           - On what platform and or device model are you seeing this ?
M.
