11-03-2011 11:43 AM
When setting up ip addressing with subnetting, what address does the ethernet connection to the router get? For example: The subnet is 192.168.18.0/24, Would Fa0/0 be 192.168.18.1 ? And would that be the Default Gateway? Finally, would that also be the first host address or would that be .2 ?
Any help is much appreciated, Frank.
Solved! Go to Solution.
11-03-2011 12:28 PM
.1 is commonly used as the router / default gateway address. It doesn't have to be though - it's just a (very) common practice.
Hosts can be any unique usable address in the subnet. Some folks start off with .2; others like to give themselves some reserved addresses for future network devices so start the host numbering at .5 or .10 (up through .254 in a /24 subnet).
It's useful thinking/troubleshhoting-wise to have some reserved addresses together for things like a possible backup router, mgmt interfaces on the network equipment, etc.
Hope this helps.
11-03-2011 12:28 PM
Hope this helps.
11-03-2011 01:17 PM
Thanks MKLemovitch, I appreciate your taking the time to help me out.
