Highlighted
Beginner
IP Port on Cisco firewall
Good morning,
I need to open UDP/TCP port 10349 outbound and the dynamic port UDP port 49152-65535 on a Cisco ASA 5515 but I can't access the firewall via SSH. Is it possible or the firewall can be managed only via the management cable? If I open the port on the router (Cisco 800 series) it will works anyway?
I'm new to Cisco and CLI command
Thank You in advice
Parravicini Filippo
2 REPLIES 2
Highlighted
Beginner
Cisco ASA can be managed via SSH as well as Telnet and Console Cable however ssh and telnet require configuration, if it's not in place then you wont be able access it via ssh/telnet. First use console cable to connect to ASA then check if there is required configuration for ssh if yes then please check if ASA allowing incoming ssh connection if you are trying to connect from "internet zone".
Highlighted
Hi, SSH is already configured. I access the router via SSH from the office. I need the command line command for open the port
Content for Community-Ad
