ā04-23-2012 06:54 AM
Hi all !
I'm an intern in a network company, in France. I'm working on IP SLAs operations on a 2821 router.
I've configured the ICMP Path Echo operation in a lab as following :
(on R1, IOS c2800nm-advipservicesk9-mz.151-2.T2)
ip sla 5
path-echo 192.168.2.2 source-ip 192.168.1.254
frequency 30
ip sla schedule 5 start-time now life 150
It works. But I can't find the command which will give the value of RTT for each hop.
I've tried this :
R1-2800#sh ip sla statistics 5
IPSLAs Latest Operation Statistics
IPSLA operation id: 5
Latest RTT: 1 milliseconds
Latest operation start time: 15:43:19.379 GMT+2 Mon Apr 23 2012
Latest operation return code: OK
Operation time to live: 145 sec
Then, this :
R1-2800#sh ip sla statistics aggregated 5 details
IPSLAs aggregated statistics
Start Time Index: 15:43:19.383 GMT+2 Mon Apr 23 2012
Path Index: 1
Hop in Path Index: 1
Type of operation: path-echo
Number of successes: 5
Number of failures: 0
Failed Operations due to over threshold: 0
Failed Operations due to Disconnect/TimeOut/Busy/No Connection: 0/0/0/0
Failed Operations due to Internal/Sequence/Verify Error: 0/0/0
Target Address 10.0.0.2
Distribution Statistics:
Bucket Range: 0-19 ms
Avg. Latency: 1 ms
Percent of Total Completions for this Range: 100 %
Number of Completions/Sum of Latency: 5/5
Sum of RTT squared low 32 Bits/Sum of RTT squared high 32 Bits: 5/0
Operations completed over threshold: 0
Path Index: 1
Hop in Path Index: 2
Target Address 192.168.2.2
Avg. Latency: 1 ms
Well, I know that I can find the value with the value of "Sum of Latency", by subtracting the actual value from the one get just before.
It would be very usefull to know directly the RTT value for each hop. Does any command give it ?
Thanks.
Regis
ā05-22-2012 12:04 AM
Does anybody have an idea ? Please !
Regis
ā05-22-2012 06:53 AM
There is no command which will show you RTT for each hop. You need to configure several probes from the source - one for each hop in the path.
