IP SLA not capturing packet loss
jzhang135
Hi All,
Currently my company uses Cisco 1811's for our sites which goes through a provider to our primary router a 3825. The existing IP SLAs we have in place are icmp-jitter types, which isn't capturing packet loss. So I have created a new IP SLA to do just that. IP SLA 10 is the existing one, and 30 is the new one. The 3825 has the ip sla responder activated. Yesterday we experience a site which had a rather high percent packet loss when ping'ed (around 8% loss), so I thought it would be a rather good time to test. But it wasn't detecting any packet loss, did I enter something wrong?
ip sla 10
icmp-jitter 10.210.1.8 num-packets 20 interval 40
frequency 600
ip sla schedule 10 life forever start-time now
ip sla 30
udp-jitter 10.210.1.8 5000
frequency 300
ip sla schedule 30 life forever start-time now
ip sla reaction-configuration 10 react packetLoss threshold-type immediate threshold-value 5 1 action-type trapOnly
ip sla logging traps
snmp-server enable traps syslog
5 Replies 5
yjdabear
How did you determine that "it wasn't detecting any packet loss"? Was there no entry in the logging buffer (show log) on the 1811 (IP SLA source), or no SNMP trap received on your SNMP server?
Shouldn't the 10 above be 30 instead?
Well using ping from the 1811 to the 3825, 1000 times, we would get anywhere from 30 to 80 packet loss. I look at IP SLA stat and shows nothing for packet loss. And yes that 10 is 30, sorry (it's configured correctly as 30 in the router).
jzhang135
Bump for ANY advice?
I think a trace is in order here. The udp jitter operation is using port 5000, what port is used by the cli ping?
Please post a trace of the traffic with the operation running, and running a failing ping operation; alsoi include the cli output showing the ip sla stat showing zero loss.
Curtis
Thanks for replying. I have no idea what port the ping command is using (I didn't know you can specify what port ping uses). We have already fixed the packet loss issue (duplex mismatch). But here's the ip sla stat, values under Packet Loss Values were all 0 when we were experiencing packet loss as well.
Round Trip Time (RTT) for       Index 30
        Latest RTT: 10 milliseconds
Latest operation start time: *20:20:52.002 UTC Thu Nov 4 2010
Latest operation return code: OK
RTT Values:
        Number Of RTT: 10               RTT Min/Avg/Max: 10/10/10 milliseconds
Latency one-way time:
        Number of Latency one-way Samples: 0
        Source to Destination Latency one way Min/Avg/Max: 0/0/0 milliseconds
        Destination to Source Latency one way Min/Avg/Max: 0/0/0 milliseconds
Jitter Time:
        Number of Jitter Samples: 9
        Source to Destination Jitter Min/Avg/Max: 1/1/1 milliseconds
        Destination to Source Jitter Min/Avg/Max: 1/1/1 milliseconds
Packet Loss Values:
        Loss Source to Destination: 0           Loss Destination to Source: 0
        Out Of Sequence: 0      Tail Drop: 0    Packet Late Arrival: 0
Voice Score Values:
        Calculated Planning Impairment Factor (ICPIF): 0
        Mean Opinion Score (MOS): 0
Number of successes: 10
Number of failures: 0
Operation time to live: Forever
To further my question in my original post, how would one implement packet loss SLA and send trap to SNMP server when there is packet loss?
EDIT: Today I noticed a site dropping packets, not as much as the one I mentioned before, here is the ping result and ip sla stat:
Router#ping 10.210.1.8 r 100
Sending 100, 100-byte ICMP Echos to 10.210.1.8, timeout is 2 seconds:
Success rate is 96 percent (96/100), round-trip min/avg/max = 24/27/40 ms
        Latest RTT: 28 milliseconds
Latest operation start time: *19:18:57.241 UTC Fri Nov 5 2010
RTT Values:
        Number Of RTT: 10               RTT Min/Avg/Max: 28/28/28 milliseconds
Jitter Time:
Packet Loss Values:
Voice Score Values:
Number of successes: 12
