ip sla operations with different keys for the same destination
ROMAN TOMASEK
Beginner
Beginner
  Hi all,
the customer wants to use different ip sla operations for the same destination (ip sla responder). From the first source router he uses key key1 and from the second source router he uses key key2. The ip sla responder responds only for the first router which uses the key key1.:-( Is it a normal behaviour? Can I use different keys for different ip sla operations for the same ip sla responder?
See the configuration on the responder:
key chain test
key 1
  key-string 7 *key1*
key 2
  key-string 7 *key2*
ip sla key-chain test
ip sla responder
He tried to use ip sla responders on:
Ciscu 2911
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M3, RELEASE SOFTWARE (fc2)
Cisco 881
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Thank you.
Roman
0 Replies 0
Recognize Your Peers
