Cisco Community Designated VIP Class of 2020
691
Highlighted
Beginner
IP SLA Proactive xofy bug
Hi All,
Has anyone came across this weird bug that when you configure ip sla in proactive with xofy, it will generate two syslog messages?
Here is how I am using it:
ip sla reaction-configuration 3 react rtt threshold-value 100 70 threshold-type xofy 2 5 action-type triggerOnly
Mar  5 10:27:06.976: %RTT-3-IPSLATHRESHOLD: IP SLAs(3): Threshold below for rtt
Mar  5 10:27:06.980: %RTT-3-IPSLATHRESHOLD: IP SLAs(3): Threshold below for rtt
And therefore, causing EEM to act twice ..which is a memory/cpu waste.
Mar  5 10:26:47.516: %SYS-5-CONFIG_I: Configured from console by vty1
Mar  5 10:26:47.620: %SYS-5-CONFIG_I: Configured from console by vty2
Using average or immediate works just fine.
One more thing ..i'm not sure if I understood 'average' , does it mean that if you have it configured for 5 attempts , you for example get a failure today, and the other day another 4 failures then it will trigger?
Here is my IOS:
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 15.0(1)M
2 REPLIES 2
Beginner
The same results comes from c871 and c1811 too.
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(15)T10, RELEASE SOFTWARE (fc3)
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 15.0(1)M, RELEASE SOFTWARE (fc2)
Beginner
anyone help?
Content for Community-Ad
July's Community Spotlight Awards
