ā03-05-2012 02:35 AM
Hi All,
Has anyone came across this weird bug that when you configure ip sla in proactive with xofy, it will generate two syslog messages?
Here is how I am using it:
ip sla reaction-configuration 3 react rtt threshold-value 100 70 threshold-type xofy 2 5 action-type triggerOnly
Mar 5 10:27:06.976: %RTT-3-IPSLATHRESHOLD: IP SLAs(3): Threshold below for rtt
Mar 5 10:27:06.980: %RTT-3-IPSLATHRESHOLD: IP SLAs(3): Threshold below for rtt
And therefore, causing EEM to act twice ..which is a memory/cpu waste.
Mar 5 10:26:47.516: %SYS-5-CONFIG_I: Configured from console by vty1
Mar 5 10:26:47.620: %SYS-5-CONFIG_I: Configured from console by vty2
Using average or immediate works just fine.
One more thing ..i'm not sure if I understood 'average' , does it mean that if you have it configured for 5 attempts , you for example get a failure today, and the other day another 4 failures then it will trigger?
Here is my IOS:
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 15.0(1)M
ā03-05-2012 04:16 AM
The same results comes from c871 and c1811 too.
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(15)T10, RELEASE SOFTWARE (fc3)
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 15.0(1)M, RELEASE SOFTWARE (fc2)
ā03-07-2012 11:44 PM
anyone help?
