IP SLA ?
MUKUL JOSHI
I am going through IP SLA right  now ??
Can someone tell me what is RTTMON MIB. And how information is retrieved by NMS from router CLI !!
Hi Mukul,
Kindly refre to the below doc link :-
http://www.cisco.com/en/US/partner/docs/ios/ipsla/configuration/guide/sla_threshold_mon.html
Obtaining the measurements is another important aspect of performance  monitoring. SAA provides data access through the command line interface  (CLI) or Simple Network Management Protocol (SNMP) via RTTMON MIB. The  CLI is a convenient way to configure and run SAA operations, as well as  to view statistics. For a larger scale monitoring, external applications  can programmatically access the SAA measurements using the RTTMON MIB.
SAA stores some amount of historical data. In addition to providing the  latest measurement, it can also store this data in an aggregated format.  With the new enhanced history feature, a user or an application can  configure SAA to store aggregated measurements in "buckets." For  example, SAA can be configured to store forty-eight buckets, and each  bucket maintains fifteen minutes of the aggregated measurements. With  this configuration, it can store twelve hours of performance  information.
SAA can also report information asynchronously. A user or an application  can configure an SAA operation with a set of thresholds. An SNMP trap  will be generated if any threshold is crossed. A potential use of such  trigger is to link it with a paging and email system. When a threshold  is crossed, the responsible administrator can be notified in real time.  Further, a threshold crossing can trigger a new SAA operation to  complete more detailed investigations such as hop-by-hop measurements.  These features can significantly reduce the mean time to repair, a key  component in most SLAs.
http://www.cisco.com/en/US/partner/tech/tk648/tk362/technologies_white_paper09186a00800e9012.shtml
Here is the SNMP Object Navigator link that list all the OID under RTTMON-MIB
RTTMON-MIB:
http://www.cisco.com/pcgi-bin/Support/Mibbrowser/mibinfo.pl?mn=CISCO-RTTMON-MIB
Hope it helps,
Many Thanks,
Gaganjeet Singh
MUKUL JOSHI
Any answer any links that can help me out
thnx
Hi Mukul,
RTTMON-MIB:
Hope it helps,
Many Thanks,
Gaganjeet Singh
THNX gaganjeet
