IP tracking and DHCP snooping
gerdo1961
Hello all,
               I have set up dot1x on our network and enabled IP tracking. I checked the IP tracking database and it is empty, but as soon as I enable DHCP snooping, the IP tracking database becomes populated. Can anyone explain to me why this happens? Do I need DHCP snooping enabled in order for IP tracking to work?
Thanks.
pieterh
IP device tracking can function independently from DHCP snooping by using ARP probes
but information can be added from the DHCP snooping database to add MAC - IP mappings
look at this document IP Device Tracking (IPDT) Overview
behavior can vary depending on OS version "on more recent Cisco IOS® releases, its interdependencies are enabled by default "
as result on latest versions 16.x IPDT can automatically be activated by activating dot1x !!!
