06-18-2008 08:55 AM
i have install IPM application but is not working as expected,please does anyone have any material related to this that i can o thru.
Please reply thanks in advance,cheers.
06-18-2008 09:06 AM
Here is the link to the IPM 4.0 user guide:
06-19-2008 04:45 AM
the problem am facing is that under IPM,tabs like Admin,Reports and Collector Management pages can`t be displayed.
Do you know what to do to restore this,please reply,thanks.
06-19-2008 04:09 AM
What is the problem you are facing?
Farrukh
06-19-2008 04:44 AM
06-19-2008 05:15 AM
page's cant be displayed = ?
Can you post a screen-shot.
Are other applications displaying fine? DFM,CS,CM?
Farrukh
06-19-2008 05:57 AM
am having problems attaching the screen shot cos the size is above the max size for attachment.DFM is also behaving the same way "page cannot be displayed".
Can somebody please help me.
06-19-2008 05:59 AM
Are all your CiscoWorks services running?
You can check this via CiscoWorks common services.
Farrukh
06-19-2008 06:28 AM
Yes i have check all the vis common services>server>admin>processes,the process state for all is stated though some are yet to receive mgt message.
Do you think if i re-install the IPM it will work?
Please kindly help me,thanks.
06-19-2008 08:43 AM
Try this:
net stop crmdmgtd
net start crmdmgtd
If this doesnt work, reboot.
If that does not work either, please let us know.
Farrukh
06-19-2008 08:51 AM
I have uninstall and re-install,now am trying to do the settings,thanks.
