IPv6 Network Management and IP SLA
massipace
I have to plan a network infrastucture with MPLS-IPv4, IPv4 and IPv6 routing tables.
Since I have an hybrid network and dual stack IPv4/IPv6 routers I must manage both protocols for all boxes using SNMP and IP SLA.
Can the SNMP IPv4 traps from the router targeted to the network management station carry information about IPv6 interfaces ?
I found the IP SLA is supported in IPv6 networks for some measurements, is required IPv6 enabled on the IP connection between the management station and the responder?
Massimiliano
Joe Clarke
First, traps can be sent over IPv4 transport and contain IPv6-related varbinds.  Second, I'm not sure I understand why you would need IPv6 enabled between the management station and the responder.  The management station will only perform IP SLA configuration options on the IP SLA source device.
Joe Clarke
