Is it possible to link ISE TACACS OTP?
CCC3
TACACS authentication is performed through ISE.
I'm thinking of OTP for additional security.
Does ISE support the interworking and setup so that I can receive additional OTP after TACACS authentication?
Tacacs for admin ?
If yes then I think cisco ise support Duo ISE integration for admin 2fa
MHM
I don't think it's admin TACACS,
I think they are trying to get users to request an additional OTP value when they log in to the equipment with a TACACS account, so that they can successfully access TACACS after going through 2 authentication.
https://duo.com/docs/ciscoise-api
check this for mote info about ISE Duo Integration
MHM
