Wayne
You can send syslog messages, SNMP notifications (traps) and syslog messages embedded within SNMP notifications (traps), concurrently to as many hosts as you like.
logging host ?
snmp-server host ?
You can add these cmds as many times as you like, to specify where each has to go. After adding the hosts, if you inspect show run, you will see the different hosts are present in the config. Now, if you issue and inspect the output of show logg and show snmp, you will see the reference to the individual hosts where the pkts are being sent to.
It works .... Palani
