agiacometti
Beginner
is it possible to share personal dashboard with other users in Prime
Hi, well the question is simple.
I had created a couple of dashboards in Prime, but none other users is able to see them.
They are not in the tabs.
Only system defined dashboards a visible to all users?
best regards
3 REPLIES 3
cristian26
Beginner
I have the same problem, i've tried creating the dashboard with root user but i cant find the option to share this dashboard with other users or for them to inherit it.
PD:CPI ver 2.2
steiostb1
Beginner
I have the same problem. I would like to make my dashboard as the default dashboard for all users. I can find an option at all to change default dashboard for users (not even the system defined ones).
Running PI 3.1.
Hi.
I realize this is a really old thread, but did anyone figure out how to share dashboard setting among other users? It would be acceptable to be able to set super admins dashboard as a default to other users.
Working with NOC users is hard as everyone must first create a similar dashboard for them selfs..
