11-29-2023 02:18 AM - editado 11-29-2023 02:18 AM
We are currently trying to tie up redundancy using ISE version 3.2.
Also, at the customer's request, forward/reverse registration is not currently in DNS.
However, I set each other's IP and FQDN using the ip host command.
As far as I know, redundancy is tied up with just the ip host command.
If you attempt duplication, a failure log will appear as shown in the attached file below.
Are you aware of this issue?
ISE model is 3755.
em 11-29-2023 03:16 AM
is this config done on ISE side.
DNS is must - i do not believe baseline not changed much even the version increased :
3.2 guide -
em 11-30-2023 03:53 PM
hello.
The IP HOST command is set in ISE.
They were set to face each other's IP/FQDN,
We are fully aware that DNS registration is essential.
However, as we have built several ISEs, we know that redundancy was possible with just an IP host.
But now an error has occurred, so I'm trying to check if it's a bug in version 3.2 or if there's another problem.
em 11-30-2023 11:53 PM
Let me be honest - i never tried that ( we generally use host entry to test in normal PC to punch DNS Entry before make any changes on the main DNS system,
as i take it was worked for you before version (not sure what version) and that is not working on ISE 3.2 (that take as defective as TAC case - can you open a TAC case to investigate for you ?)
On personal intrest when you using host entry ISE point to what DNS Server, does command level able to resolve that DNS entry when you ping from CLI or do nslookup ?
em 11-29-2023 04:04 AM
Make redundacy meaning use two PSN?
For which purpose you use ISE?
em 11-30-2023 03:55 PM
We are building ise to do tacacs.
It is still in the early stages of construction and redundancy is being tied up.
em 12-02-2023 11:51 AM
there is a bug in 3.2 where the DNS query fails when the hostname contains a dash. (-). To verify if you are hitting that bug, what if you use e.g.:
ISETACACS02.kt.com
em 12-10-2023 05:12 PM
hello.
The answer was late.
Currently, there is no two-way registration in DNS.
Only ip host is set.
Does the bug you reported apply equally to IP hosts?
Also, can you tell me the bug report ID?
Descubra e salve suas ideias favoritas. Volte para ver respostas de especialistas, passo a passo, tópicos recentes e muito mais.
Novo por aqui? Comece com estas dicas. Como usar a Comunidade Guia do novo membro
