ISIS MIB Doesn't work on Adagios for Cisco 2911 running IOS Version 15.1(4)M1
Trilok Kataria
Level 5
Level 5
I have an issue with ISIS MIB on Cisco 2911 running IOS Version 15.1(4)M1 which supports the MIB as per Cisco SNMP MIB Locator.
This host has many others services which are working fine except ISIS Adjacency e.g. Ping, Device Uptime etc.
SNMP Config on the router:
router#sh run | i snmp
snmp-server community xxxxx RO 10
snmp-server enable traps isis
router#
SNMP Status/Walk on our Linux server:
[nocadm@linmonpx02 ~]$ snmpstatus -v 2c -O v -c 534747544D444953 x.x.x.x >>>> Ip removed
[UDP: [195.110.243.126]:161->[0.0.0.0]]=>[Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 14-Jun-11 19:25 by prod_rel_team] Up: 165 days, 14:19:07.56
Interfaces: 0, Recv/Trans packets: 0/0 | IP: 1009581153/282594876
1 interface is down!
[nocadm@linmonpx02 ~]$ snmpstatus -v 2c -O v -c 534747544D444953 x.x.x.x -m 1.3.6.1.4.1.9.10.118 >>>>ciscoIetfIsisMIB
No log handling enabled - turning on stderr logging
Cannot find module (1.3.6.1.4.1.9.10.118): At line 1 in (none)
[UDP: [x.x.x.x]:161->[0.0.0.0]]=>[Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M1, RELEASE SOFTWARE (fc1)
Compiled Tue 14-Jun-11 19:25 by prod_rel_team] Up: 165 days, 14:19:33.22
Interfaces: 0, Recv/Trans packets: 0/0 | IP: 1009617227/282595300
SNMP Debug Packet output from the router:
052885: May 10 15:25:09.145 UTC: SNMP: Packet received via UDP from 172.29.100.73 on GigabitEthernet0/2.1
052886: May 10 15:25:09.149 UTC: SNMP: Get request, reqid 1012751535, errstat 0, erridx 0
system.1.0 = NULL TYPE/VALUE
sysUpTime.0 = NULL TYPE/VALUE
ip.3.0 = NULL TYPE/VALUE
ip.10.0 = NULL TYPE/VALUE
052887: May 10 15:25:09.157 UTC: SNMP: Response, reqid 1012751535, errstat 0, erridx 0
system.1.0 = Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M1, RELEASE SOFTWARE (fc1)
sysUpTime.0 = 1430778486
ip.3.0 = 1009913920
ip.10.0 = 282599056
052888: May 10 15:25:09.173 UTC: SNMP: Packet sent via UDP to 172.29.100.73
052889: May 10 15:25:09.273 UTC: SNMP: Packet received via UDP from 172.29.100.73 on GigabitEthernet0/2.1
052890: May 10 15:25:09.281 UTC: SNMP: Get-next request, reqid 1012751536, errstat 0, erridx 0
ifOperStatus = NULL TYPE/VALUE
ifInUcastPkts = NULL TYPE/VALUE
ifInNUcastPkts = NULL TYPE/VALUE
ifOutUcastPkts = NULL TYPE/VALUE
ifOutNUcastPkts = NULL TYPE/VALUE
052891: May 10 15:25:09.293 UTC: SNMP: Response, reqid 1012751536, errstat 0, erridx 0
ifOperStatus.1 = 2
ifInUcastPkts.1 = 0
ifInDiscards.1 = 0
ifOutUcastPkts.1 = 0
ifOutDiscards.1 = 0
052892: May 10 15:25:09.309 UTC: SNMP: Packet sent via UDP to 172.29.100.73
052893: May 10 15:25:12.609 UTC: SNMP: Packet received via UDP from 172.29.100.73 on GigabitEthernet0/2.1
052894: May 10 15:25:12.613 UTC: SNMP: Get request, reqid 1232957972, errstat 0, erridx 0
052895: May 10 15:25:12.621 UTC: SNMP: Response, reqid 1232957972, errstat 0, erridx 0
sysUpTime.0 = 1430778832
ip.3.0 = 1009918763
ip.10.0 = 282599133
052896: May 10 15:25:12.637 UTC: SNMP: Packet sent via UDP to 172.29.100.73
052897: May 10 15:25:12.741 UTC: SNMP: Packet received via UDP from 172.29.100.73 on GigabitEthernet0/2.1
052898: May 10 15:25:12.741 UTC: SNMP: Get-next request, reqid 1232957973, errstat 0, erridx 0
052899: May 10 15:25:12.753 UTC: SNMP: Response, reqid 1232957973, errstat 0, erridx 0
ifOperStatus.1 = 2
ifInUcastPkts.1 = 0
ifInDiscards.1 = 0
ifOutDiscards.1 = 0
052900: May 10 15:25:12.765 UTC: SNMP: Packet sent via UDP to 172.29.100.73
Any suggestion/ideas would be highly appreciated :)
jossabor
Please try a simple snmpwalk using that OID:
snmpwalk -v2c -c <community> <ip> <OID>
Also make sure that the device is reachable. On the debug we can not see the request received for that OID.
Please try also using an OID inside of the MIB Table.
