Hi!
Apologies if this has already been discussed. I was unable to find information.
Platform: ISR4k series routers. I have been testing IOS-XE 17.5.1a and 17.6.3a.
The router day0 configuration has ipsec enabled and needs the ISR_4400_Security license. The license has been installed on the box with SLR/SLUP. It's working.
Problem: when testing ZTP I have used the command "factory-reset keep-licensing-info" to erase config and start ZTP on reload. Contrary to the documentation this command seems to delete the "license boot level" config. The licenses are intact however.
This leads into situation where configuration applied by ZTP does not work because the router rejects e.g. all "crypto ike" and "crypto ipsec" commands. In order to make them work one needs to perform:
conf t
license boot level securityk9
wri mem
reload
But if I insert the above commands into ZTP python script the ZTP is not activated on next reload and actual router config is not installed.
Here's again what happens:
(router reloads)
ZTP starts and downloads python script which downloads config
copy tftp://TFTP.SERVER.IP/day0-router-config nvram:startup-config
Copy finishes and ZTP script reloads the router
Router boots with day0 config and rejects all crypto lines. Result: the config does not work at all.
