xidasd
Beginner
ISR 4321 "debug ip icmp" command not capture icmp packet
Hello, when trying to enable  icmp debug by using command "debug IP icmp" in ISR 4321 router, it doesn't capture received icmp packets. But if i send icmp packet to others from the router, the router capture icmp packet normally. Does this situation be normal?
show version
Cisco IOS XE Software, Version 16.08.01
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.8.1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 27-Mar-18 13:43 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
CENT-R uptime is 9 minutes
Uptime for this control processor is 11 minutes
System returned to ROM by Reload Command at 20:35:19 KST Sat Feb 6 2021
System image file is "bootflash:isr4300-universalk9.16.08.01.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
appxk9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           None             None             None
uck9             uck9             Permanent        uck9
securityk9       securityk9       Permanent        securityk9
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4321/K9 (1RU) processor with 1788457K/6147K bytes of memory.
Processor board ID FDO2241A2GG
2 Gigabit Ethernet interfaces
2 Serial interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3125247K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
2 REPLIES 2
balaji.bandi
VIP Expert
can you post the put of the debug to look what you seeing.
in general, that is natural since it processed by FAST or CEF switching.
iif you use the command no ip route-cache or no ip route-cache cep, you can get what you looking.
here is some reference :
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-software-releases-120-mainline/47205-cef-whichpath.html
you may get more details if you issue  "debug ip packets detail"  (this is more CPU intensive - be careful on the production network.)
BB
*** Rate All Helpful Responses ***
Does "debug ip icmp" command only debug data processed by CPU likewise "debug IP packet" ?
Content for Community-Ad
