ISR 4XXX LTE Dual SIM Failover & Fallback to Primary EEM Script
pgioiell
Good Morning,
  is anyone aware of a working EEM script using IP SLA/Tracker to automatically fail over to other LTE provider?
Pete
Mark Elsen
- Check if this document can be helpful :
             https://manualzz.com/doc/35644109/configuration-of-dual-sim-feature-and-sim-failove
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
pgioiell
Thanks M for info.  I found following link that has EEM script which appears to be using IP SLA/Tracker to cause the script to do the switch.   Is anyone aware of this working or a similar script with the same functionality?
https://community.cisco.com/t5/network-management/819-4g-dual-sim-failover-amp-fallback-to-primary/td-p/3991024
