Community Helping Community
332
Highlighted
Beginner
issues in CPI 1.3
hi every body ,
first problem :
I integrated CPI with ACS and i add super admin specially to authenticate against ACS , although the authentication working fine through the ACS but some of features are disappear . However when i login locally by same user role the features are appear .
second problem:
Some of switches like 3750,3550 ,are shown unknown in temperature field in detail dashboard , while the other types like 6500 are shown the actual temperature .
Everyone's tags (2)
5 REPLIES 5
Collaborator
issues in CPI 1.3
- Which features appear and or disappear ?
M.
Beginner
issues in CPI 1.3
these features :
Custom SNMP Template
Moinitoring Configuration
Associate End points to the Site
issues in CPI 1.3
Send me your SNMP configuration
and monitoring configuration
and through which level of user you are monitoring
Rate it
Beginner
issues in CPI 1.3
aman
when i try to login with Tacacs (ACS) the custome snmp feature disappear and that user is configured as Admin role but through ACS not locally .
However when i login with local admin role i can see this feature.
Beginner
issues in CPI 1.3
I solved the first problem by readding the tasks in ACS.
For the tempature i try adding internet ,system ,interfaces ,cisco ,chassis  in SNMP view but still the
temperature value Unknown for 3750 switches
Content for Community-Ad
July's Community Spotlight Awards
