Issues with DFM application
sameoj1881
am having issues with DFM i installed.
Tabs home,alerts and activities,devices management,fault history,notification services and configuration pages cannot be displayed each time i click any of them.
Does anyone know how to fix this issues,please reply,thanks.
tstanik
Level 5
Level 5
From the Admin Console->DFM then in the right pane under Domain "DFM" you should see a box for the default community string change it to yours then select the Inventory Menu and do
1) Reconfigure
2) Save Inventory
Here is a link to the DFM Docs which will help you :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_device_fault_manager/3.1/user/guide/adminDFM.html
