it staff.
mirajimmbaga
%SMART_LIC-3-COMM_FAILED: Communications failure with the Cisco Smart License Utility (CSLU) : Unable to resolve server hostname/domain name.
QN:-
what a reason of the statement above from acisco switch catalyst 9300 and what is the solution of a given problem?
balaji.bandi
make you configured your DNS config on the switch :
ip name-server x.x.x.x
Do you have switch access to internet ?
if not you need to use your proxy to communicate with cisco license server.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-9/configuration_guide/sys_mgmt/b_169_sys_mgmt_9300_cg/configuring_smart_licensing.html
BB
So, I had the same issue and noticed I was missing the command below (compared with my other Cisco switches) and then added it:
and then used this one:
license smart sync all
After this, the problem disappeared.
Thanks!
Leo Laohoo
QuoVadis Root CA 2 Decommission and Transition to IdenTrust Commercial Root CA 1
Either upgrade the firmware of the switch or perform the workaround but do not leave this error message going because there is a memory leak with the "keyman" process.
