Running ITM 2.0 IDU6 on win2k. When trying to rediscover 2 servers, I am getting a "DataCollector request timeout (internal problem)" error message. What does this mean and is there a workaround?
This error means that the inventory collector has problems communicating with the VHM/DFM servers. Meanwhile you should try a cw2000 daemon manager restart and then select the two devices and rediscover them again.
