09-05-2006 03:57 PM
Hi all,
using CiscoView with a 2950 trying to configure a port results in a java.lang.NullPointerException. Doing the same on a 2960 works fine.
I already deleted and reinstalled Version 6 of Cat2950 package but it didn't solve the issue.
What can I do?
Solved! Go to Solution.
09-06-2006 11:52 AM
From what I can see the CiscoView package supports the 2950 if it runs 12.1(19)EA1 or later.
09-05-2006 04:52 PM
What version of code are you running on the 2950? What version of CiscoView?
09-06-2006 11:36 AM
acutally the versions are the following:
LMS 2.5
CiscoView 6.1.4
CV Package cat2950 v6.0
Device cat295048g (C2950-I6Q4L2-M)
IOS 12.1(6)EA2a
Chasis -> Configure works fine.
Port -> Configure gets Failed to create dialog due to java.lang.NullPointerException
Port -> Monitro works fine
Ruedi
09-06-2006 11:52 AM
