05-04-2015 11:50 AM
Anyone have any issues when they attempt to run or schedule a CLI template job to a group of devices? Mine never deploy and just stay in a scheduled state. It's been like this since upgrading to 2.2. The job will only run if I reboot the prime server or start & stop the NCS services. So far Cisco TAC hasn't been able to provide any insights. It's likely they'll recommend a full reinstall.
Brian
05-06-2015 09:00 AM
Have you installed the 2.2.1 patch?
https://software.cisco.com/download/release.html?mdfid=286236028&softwareid=284272933&release=2.2.1&flowid=72882
05-06-2015 09:03 AM
Yes, that was the recommendation of the Cisco TAC Engineer but it didn't make a difference. Pretty frustrating to have to reboot Prime every time we want to deploy a configuration change to our devices.
05-06-2015 09:14 AM
Can you provide a show version?
https://tools.cisco.com/bugsearch/bug/CSCut24673
There is a patch for this.
05-06-2015 09:24 AM
Cisco Application Deployment Engine OS Release: 2.3
ADE-OS Build Version: 2.3.0.101-root
ADE-OS System Architecture: x86_64
Copyright (c) 2005-2010 by Cisco Systems, Inc.
All rights reserved.
Hostname: pdciscoprime001
Version information of installed applications
Cisco Prime Infrastructure
Version : 2.2.0
Build : 2.2.0.0.158
Installed Updates:
Critical Fixes:
PI 2.2.1 POODLE Fix ( 1.0.0 )
PI 2.2.1 Maintenance Release ( 1.0.0 )
Installed Updates:
Device Support:
Prime Infrastructure 2.2 Device Pack 3 ( 3.0 )
05-06-2015 09:51 AM
No, its not publicly available. Best bet is to open a case and reference the Bug ID.
05-11-2015 04:39 AM
I have a issue like Brian but with Configuration Archive Jobs... When I want start a configuration archive job "now", the jobs goes in state "schedule" and it will be run a few hours later... If I schedule a job at a fixed time, it will be execute at a random time, never the same...
In fact, the Configuration Archive Jobs are never execute a the good time...
I also have Prime Infrastructure build 2.2.0.0.158 with patchs:
Critical Fixes:
Any idea ?
thanks for your help
Sam
05-21-2015 12:34 AM
rebooting prime is a workaround for this issue - see https://supportforums.cisco.com/discussion/12486326/pi22-jobs-not-starting
05-21-2015 07:23 AM
Yes, rebooting will temporarily fix the problem but I've had it reoccur within an hour of rebooting. Considering a reboot takes about 20 mins or so for the services to start / stop it's definitely not ideal. I still have an open ticket with Cisco TAC. When I get word on their fix I will post here.
06-29-2015 05:41 AM
You would be hitting the bug: https://tools.cisco.com/bugsearch/bug/CSCuu34991.
Please have TAC engineer to validate this on your case and apply the work around.
This would be fixed in PI 2.2.3 version.
thank you.
Govardhan
06-29-2015 11:59 PM
thank you Govardhan & Daniel for your reply ...
I will contact the TAC to obtain this patch...
Have a good day
Sam
06-29-2015 09:02 AM
I also had this bug. I called TAC and they patched it up fine. There is a script they have to download and run to clean up some DB table entries among other things. Painless and now my Prime works fine again: jobs run as expected, and I see all the information on my dash.
05-06-2015 09:34 AM
Is that patch available for download? Can't seem to find it.
05-19-2015 06:51 AM
Been working with Cisco TAC on this one and it's been identified as a bug and they're working on a fix.
06-29-2015 04:33 AM
Hi Brian,
do you have any news from TAC about this bug ?
