Jumbo frames over 1Gbps link and speed tweak
Frank27
I have this network configuration :
cisco 7201 router --> Nexus N5k --> ASA5525 --> Host
they are running at 1Gbps speed. I would like to improve the overall performance of the network.
So It came to my mind to  higher the MTU size for example.
Makes sense to have jumbo frames over a 1Gbps link? Normally they are used on 10Gpbs one.
What other network improvements should I use as general remarks?
Depening on the size of your network, considering you are running over 1 giga link, unless you are facing some performance issue, I dont see what and why you are going to change configuration. Now, if you are running into performance problem, then, I advise you try to track down what is causing.
 Do you have any tool to monitor the network?
Mark Elsen
              - FYI : https://routerguide.net/jumbo-frame-on-or-off/
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
ASA in path  I don't think that ASA support jumbo, and this make ASA frag/defrag Packet with inspection it nightmare.
Joseph W. Doherty
BTW, going from an Ethernet 1500 MTU to a jumbo, might indeed improve throughput, but only usually by a few percent.
If you believe you have a performance issue, you need to first truly identify the "bottleneck" and mitigate it (laugh, unfortunately, this often leads to finding the next bottleneck).
I don't firmly recall the specs on the 7201, but, I recall, it performed like a NPE-G1 or G2, neither of which guarantees gig throughput (the -G# is for PPS, not bps).
I'm unfamiliar with ASA models performance, but FW can often be a throughput bottleneck.
