Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Juniper is not supported by Prime Infrastructure, the only 3rd party device that is currently supported is Aruba wireless controllers and access points. You can refer to the supported devices list from the link below:
