LAN monitoring
ahmad82pkn
Level 2
Level 2
Hi, is there any tool to monitor which computers in my network (LAN) are consuming most of the bandwidth?
Actually my cisco 4507 Switch has intervlan routing, and consume a lot of CPU, so i want to diagnose which systems are generating most of the traffics and where.
lchance
You might try downloading a Solarwinds NetFlow tool which is free then configure NetFlow on your 4500 and see where the traffic is coming from on that vlan.
Solarwinds has some documents online which should show how NetFlow is configured if you've never worked with it.
