02-07-2023 10:21 PM - edited 02-07-2023 10:41 PM
Needed to understand if Cisco Switch CISCO3925-CHASSIS needed restart after HSEC traditional license installation Or it can run without reload kindly suggest
Solved! Go to Solution.
02-07-2023 11:00 PM
Only installing HSEC9 License not required to reboot, But if you like to increase throughput levels you need to reload to take effect.
https://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html#53013
02-07-2023 11:00 PM
