Limiting Cisco interface information for SNMP
mseppanen
Hello!
Does anybody know is it possible to limit specific Cisco-device based interface information by iftype or something else with snmp view commands or something else in IOS? Many NMS:s could make use of that feature not getting too much information i.e Enterprise level routers with many thousands of virtual interfaces.
Marko Seppanen
smahbub
Level 6
Level 6
SNMP view is a mapping between SNMP objects and the access rights available for those objects. An object can have different access rights in each view. Access rights indicate whether the object is accessible by either a community string or a user, refer the following link for configuring a snmp view :
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800ca66b.html#1001150
Hello Shumon!
Thank you for your answer! I'll agree precisely like you say. Still there's no means on Cisco to do what i earliear described, dough!
Marko Seppanen
