Hi All,
We are currently using 2 nexus 5548UP. However, not sure what would be the right way to configure LINE VTY and Console.We are planning in a simple way...such as eanbling SSH and use local admin user by using which the user will logged in. So far SSH is enabled. Also local user is created with privilege 15 but no role is given. We have also created a Enable Secret.
Here is the problem:
- Every time we logged in the Enable passwork is not requesting.
- How should I configure my Console with the same user/pass given for VTY.
- Is there any issue if I do not give any Role to the user created locally.
Kindly let me know. Thanks in advance.
Adnan
