LINK FLUCTUATION PROBLEM
sachipany@
Log Buffer (4096 bytes):
s)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Te1/2 in vlan 132
000196: *May 14 10:02:27.507: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 1 times)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Te1/2 in vlan 132
000197: *May 21 17:53:51.823: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 1 times)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Te1/2 in vlan 136
000198: *May 22 07:07:26.252: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 2 times)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Te1/2 in vlan 132
000199: *May 25 21:38:09.486: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 2 has failed or been turned off
000200: *May 25 21:38:14.490: %C4K_IOSMODPORTMAN-6-POWERSUPPLYGOOD: Power supply 2 is okay
000201: *Jun 1 00:51:01.198: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 1 has failed or been turned off
000202: *Jun 1 00:52:06.222: %C4K_IOSMODPORTMAN-6-POWERSUPPLYGOOD: Power supply 1 is okay
000203: *Jun 2 00:46:05.380: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:46:05 UTC Tue Jun 2 2020 to 06:16:05 IST Tue Jun 2 2020, configured from console by cisco on vty0 (10.100.129.10).
000204: *Jun 2 00:46:05.384: %SYS-5-CONFIG_I: Configured from console by cisco on vty0 (10.100.129.10)
000205: *Jun 2 09:53:00.000: %SYS-6-CLOCKUPDATE: System clock has been updated from 06:16:05 IST Tue Jun 2 2020 to 15:23:00 IST Tue Jun 2 2020, configured from console by cisco on vty0 (10.100.129.10).
000206: Jun 9 12:07:30.885: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: Packet received with invalid source MAC address (00:00:00:00:00:00) on port Te1/2 in vlan 130
000207: Jun 28 21:01:05.542: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: Packet received with invalid source MAC address (00:00:00:00:00:00) on port Te1/2 in vlan 136
000208: Jul 7 13:07:06.534: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 2 times)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Te1/2 in vlan 136
000209: Jul 18 04:57:54.999: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: Packet received with invalid source MAC address (00:00:00:00:00:00) on port Te1/2 in vlan 136
000210: Jul 22 05:27:06.983: %SFF8472-5-THRESHOLD_VIOLATION: Te1/1: Rx power low alarm; Operating value: -33.9 dBm, Threshold value: -18.4 dBm.
000211: Jul 24 05:13:32.879: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 1 has failed or been turned off
000212: Jul 24 05:14:47.943: %C4K_IOSMODPORTMAN-6-POWERSUPPLYGOOD: Power supply 1 is okay
000213: Jul 24 05:14:52.943: %C4K_IOSMODPORTMAN-6-POWERSUPPLYFANGOOD: Fan of power supply 1 is okay
000214: Jul 24 05:15:37.983: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 2 has failed or been turned off
000215: Jul 24 05:15:52.999: %C4K_IOSMODPORTMAN-6-POWERSUPPLYGOOD: Power supply 2 is okay
000216: Jul 24 06:56:56.819: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 1 has failed or been turned off
000217: Jul 24 06:57:16.839: %C4K_IOSMODPORTMAN-6-POWERSUPPLYGOOD: Power supply 1 is okay
000218: Jul 24 06:57:21.839: %C4K_IOSMODPORTMAN-6-POWERSUPPLYFANGOOD: Fan of power supply 1 is okay
000219: Jul 24 06:59:11.859: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 2 has failed or been turned off
000220: Jul 24 07:00:36.927: %C4K_IOSMODPORTMAN-6-POWERSUPPLYGOOD: Power supply 2 is okay
000221: Jul 30 13:44:55.313: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 1 has failed or been turned off
000222: Jul 30 14:20:56.673: %C4K_IOSMODPORTMAN-6-POWERSUPPLYGOOD: Power supply 1 is okay
000223: Jul 30 14:30:07.037: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 1 has failed or been turned off
000224: Jul 30 14:46:42.613: %C4K_IOSMODPORTMAN-6-POWERSUPPLYGOOD: Power supply 1 is okay
000225: Aug 1 09:32:13.722: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 1 has failed or been turned off
000226: Aug 1 09:32:38.742: %C4K_IOSMODPORTMAN-6-POWERSUPPLYGOOD: Power supply 1 is okay
000227: Aug 1 11:43:39.462: %SYS-5-CONFIG_I: Configured from console by cisco on vty0 (10.100.138.74)
Richard Burts
There are quite a few messages like this one
I am interested in the fact that some of these messages show Re1/2 to be in vlan 130, while others show it to be in vlan 132, and still other show it to be in vlan 136. What can you tell us about Te1/2? How is it configured? What is connected to it?
Rick
6 Replies 6
Leo Laohoo
What issue?
All I can see are alarms for power supply 1.
Richard Burts
Rick
SR02-RS-SFS-407#show run int Te 1/2
Building configuration...
Current configuration : 91 bytes
interface TenGigabitEthernet1/2
description SR02-RS-SRR-816
switchport mode trunk
end
Thank you for showing us the configuration. Can you tell us what is connected on this interface? It might also be helpful if you would post the output of the command show interface trunk.
Rick
Hi!
You are having two problems:
1) One of your Power Supplies is etiher faulty or it's power source is flapping.
2) Endpoints connected via Te1/2 are sending frames with invalid source MAC (either all 0 or a Multicast MAC).
Could you share the output of the following?
Juls
Dear Sir, find the details below
SR02#show run int Te 1/2 Building configuration... Current configuration : 91 bytes ! interface TenGigabitEthernet1/2 description SR02-RS-SRR-816 switchport mode trunk end
