LMS 2.1 - 2.6 Upgrade
siiiilky
I have upgraded my install of LMS to 2.6
Now apache won't start and this error is in the error logs -:
[Thu Mar 01 10:57:34 2007] [error] Apache.exe caused a EXCEPTION_ACCESS_VIOLATION in module LIBEAY32.dll at 001B:010D527A, sk_pop_free()+26 byte(s)
Any ideas?
Joe Clarke
This is most likely due to CSCsg29627. This is caused by multiple versions of libeay32.dll and ssleay32.dll installed on the same machine. The workaround is adjust your PATH so that all of the CiscoWorks elements appear before all other elements. In particular, NMSROOT\bin must appear before any other third party path components.
