05-24-2005 01:13 PM
Hello All
I working with the CW2K LMS 2.2 and the syslog messages of all routers, I understand that are stored on the /var/log/syslog_info, and the configurations about the storage options are configured to keep messges up to 14 days on CW2K and if I have to see any massages old than this period of 14 days I must to go to file /var/log/syslog_info and execute a grep to related device. Well my doubt is related a specific device that is not possible to find any entry on the file /var/log/syslog_info, but when the syslog custon report is generated on the CW2K is possible to see the logs of the period of 14 days. Can anyone answer me why this is happening ?
PS: The device configuration are ok related the logging and the device is suported by the RME IDU 9.
Marcelo
05-24-2005 03:01 PM
Could it be that the file /var/log/syslog_info was somehow purged? Or perhaps you have Remote SAC configured?
05-25-2005 05:15 AM
Hello nhabib
Thanks for your reply, but I don´t have the purge option and the SAC configured yet.
