10-01-2010 07:29 AM
Hi Folks,
I have the following software and its updates(below). When I discover devices on my network it doesn't recognize cisco 2960 switches. When I want to upgrade the devices it says that all the updates are already installed. How can I solve this issue?? Any Ideas? How can I upgrade to RME 4.0.3?
Thanks in advance for your help.
Tito
10-05-2010 12:35 AM
Go to Common Services ---> Software Center ---> Software Update and select to download updates for all the applications. Then go to the download directory and install each update separate. The downloads should be in the psu_download directory such (/opt/psu_download/
04-07-2016 08:40 AM
same problem several years later... Did you get the updates? Could you please send them to us?
Thanks ;-)
David
