09-22-2005 12:46 AM
Hi all
I have checked the User Guide for Common Services 3.0 and I can see that ACS 3.2 is supported for use with LMS 2.5, however, I would like to confirm that ACS 3.3 will work (and is supported) for use with LMS 2.5 applications ?
I couldn't see this specified in the userguide for Common Services 3.0 or ACS 3.3, and sometimes you can't assume that the requirements in these document are minimum requirements or 'absolute' requirements ...
Many thanks for any clarification on this point
Kind regards
Marcus
09-22-2005 03:29 AM
Hi Marcus,
we have tested it with LMS 2.5 SP1 and ACS 3.3.2.
The integration runs fine and without any problems until now.
Best regards,
Frank
09-22-2005 03:38 AM
You will need to install Service Pack 2 for Common Services 3.0 to get ACS 3.3 support
Note: ACS appliance will not be supported until LMS 2.5.1
