561
Highlighted
Beginner
LMS 2.5 with TACAS
I'm planning to install TACAS on a separate machine but I read somewhere that mentioned we should install on same machine with LMS 2.5 for Windows 2003. What is your recommendations and solution to this approach. Is it better to install TACAS on a separate machine or on same machine with LMS2.5.
thanks,
2 REPLIES 2
Highlighted
TACACS can be installed on another server and it does not have to be installed on the same machine as LMS 2.5.
If you choose to use the TACACS login module on LMS it can communicate with a remote server without problem. I have often seen that it is actually better to dedicate a server to LMS 2.5 itself without any other applications installed.
Highlighted
If I choose to install on the same machine, will the database for LMS2.5 and TACAS shared together or separate.
Content for Community-Ad
