LMS 2.6 and 4507R-E
MathieuJM_2
We have LMS 2.6 on Windows 2003 and a 4507R-E.
The 4507R-E is recognized as an unknow device.
What should i do in order to include this device into LMS ?
Joe Clarke
You will need to make sure you have CS 3.0.6, RME 4.0.6, Campus 4.0.13, and DFM 2.0.13. Then, go to Common Services > Software Center > Device Update, check Common Services and Resource Manager Essentials, and download and install all available updates.
Here are the version number:
CiscoWorks Common Services : 3.0.5
Campus Manager : 4.0.6
CiscoView : 6.1.5
Device Fault Manager : 2.0.6
Internet Performance Monitor : 2.6.0
Integration Utility : 1.6.0
Resource Manager Essentials : 4.0.5
So definitively we need to upgrade the installed version.
Are all the version you mention available on LMS 2.6 ?
Yes. You first need to go to http://www.cisco.com/cgi-bin/tablebuild.pl/cd-one-3des , and download and install CS 3.0.6. After that, all the other service packs can be downloaded from Common Services > Software Center > Software Update.
