LMS 2.6 and PX-501 Firewall RME running configuration query
billy.moses
Our customer is running LMS 2.6 with all application & device patches available from CCO installed.
He is managing a PIX-501 FW v 6.3(5), there is a line in the devices config that states "pager lines 24"
The issue is that when you look at the stored configurations (in the version tree for instance) on LMS the line appears as it should do in the startup config.
When you view the running config it states "no pager".
We have doubled checked that the running config of the device states "pager lines 24"
The customer is needs assurance because he often needs to run the sync on device from LMS.
His concern is that this line will be changed or replaced with the incorrect "no pager" command.
Has anyone seen something like this before or is there a known bug / patch.
Rgds
Joe Clarke
There was a bug on this: CSCse07680. It was fixed in RME 4.0.5. If you configure the running config of the PIX to have "pager line 24", then run an RME sync archive job, that line should be back in the PIX when the job completes. If, however, the running config currently has "no pager" then that line will never revert back to "pager lines 24".
