LMS 2.6 feedback?
tcyee
I have been putting off upgrading to LMS 2.5 due to bad feedback. Have the major bugs been fixed for the 2.6 version? Feedback would be appreciated for the windows version. Also, is there an upgrade path from 2.2 to 2.6, or is it a better idea to start with a fresh install?
Joe Clarke
LMS 2.6 has a LOT of bugs fixed. I would highly recommend everyone upgrade. Thus far we have not seen any major issues with 2.6.
As for upgrading from 2.2, you will need to first upgrade to LMS 2.5.1, then move to 2.6. However, the easiest course is to do a fresh install, then migrate your 2.2 data once you are on 2.6.
