10-06-2008 01:21 AM
Running LMS 2.6 on a windows server.
I have a Pop Up showing the following message when I launch a module (CS, CM, RME,...)
âThis software is provided for demonstration purpose only and is not licensed for resale or commercial use.â
The licence file is configured in CS and seems working well instead of this message wich is boring...
Do you know how to get rid of this ? any script to launch or someting ?
Cedric.
10-06-2008 07:35 AM
It sounds like you have an SE license which is not legal. These license should only be used for Cisco-internal demos. You will need to purchase an LMS 2.6 license. Your sales team/SE should be able to help you with this.
10-08-2008 12:52 AM
Thanks for your reply. I don't think this is a SE Licence. This is one of our customers and when I look in CS > admin > licencing, The licence file .lic is taken into account and in the column 'expiration', it's writtent 'Never'so this would be a little weird for demonstration licence.
I tried to re-import the .lic file but nothing have changed.
Thanks for your help.
10-08-2008 01:16 AM
10-08-2008 07:29 AM
The SE demo license for LMS 2.6 never expires. It does not mean that this is a valid license to be giving to customers. This is definitely an SE license. Each nag message is unique, and the message you are seeing indicates an SE license. The regular eval message would be:
MESSAGE: This software is provided for evaluation purposes only and will be operational for 90 days.
Your customer must purchase a real license.
