11-10-2010 06:47 AM
We have an existing install of LMS2.6 and we recently purchased the upgrade to 4.0.
I would like to do a clean install rather than upgrade over the existing problems we currently have with the old version.
Can a clean install be done with only the 4.0 software we currently have, or does it have to be installed over 2.6?
I cannot find the existing 2.6 software that was originally installed.
11-10-2010 07:03 AM
LMS 4.0 SHOULD be installed on the clean server. So even if you have any previous LMS version you should uninstall it and clean your server. After the installation, you could restore the backup of your data if needed.
11-10-2010 08:20 AM
...and if you are on windows it would be good to read the following document from joe clarke "Tips For a Successful Installation of LMS on Windows" before starting the installation:
11-10-2010 08:27 AM
So I do not need the 2.6 software even though I have the upgrade license?
Here is what we have:
Product Name : L-CWLMS-4.0-300UP
Product Description : Upg LIC for LMS 2.x,3.x to 4.0 300 Devices, Base Kit Req
Product Qty : 1
Also, What are the VM specs needed for virtual installation (RAM, processor)?
Thanks I have seen the Joe Clark doc.
11-11-2010 12:59 AM
Server requirements - http://www.cisco.com/en/US/partner/prod/collateral/netmgtsw/ps6504/ps6528/ps11200/ps11202/data_sheet_c78-610760.html
Interesting question. Never tried such scenario. Anyway if you need installation CDs for 2.6, your account team should be able to ship them.
11-11-2010 01:53 AM
No, you do not need the installation CDs; I just updated an LMS 4.0 with an upgrade license. It was running with an eval license and it is now running as a permanent licensed installation. I was not asked for a running LMS 3.x or LMS 2.x installation or for any older installation CD/DVD.
