LMS 3.0.1 Casuser reset problem
punit.dixit
Beginner
Beginner
After restarting the lms3.0.1, daemon manager doesnt start automatically,I will have to manually resetcasuer.exe & then it will start over & again.During this time most of the processes are down with PID=-1 & wont start when i start them.What could be causing this ?
1. CiscoWorks Common Services 3.1.1 25
2. Campus Manager 5.0.4
3. CiscoView 6.1.7
4. CiscoWorks Assistant 1.0.1
5. Device Fault Manager 3.0.4
6. Internetwork Performance Monitor4.0.1
7. Integration Utility 1.7.1
8. LMS Portal 1.0.1
9. Resource Manager Essentials 4.1.1
Martin Ermel
Collaborator
Collaborator
a quick thought that comes into my mind is that you are running on windows and global policies are overwriting local settings.
