12-27-2007 07:03 PM
Does anyone experinced this problem. I have already installed LMS 3.0 and upgraded to Dec Update, but still I encounter same problem. The 10G link connection between devices were not recognized and was seen as a thick black straight line only. I have attached a screenshot for the device.
What would be the problem? thanks.
12-27-2007 08:51 PM
If you ran a Data Collection under Campus 5.0, you need to reinitialize your ANI database to complete a fix for a bug that can cause this problem. To reinit the database, run:
NMSROOT/bin/perl NMSROOT/campus/bin/reinitdb.pl
Then run a new Data Collection.
12-27-2007 09:50 PM
hi jclarke,
yes. i already did that couple of times but same thing happen.
regads,
12-27-2007 10:03 PM
Then there must be something genuinely wrong with the CDP cache on those devices. Pick two (looks like 10.144.67.37 and 10.144.2.35 would be easiest) and check their "show cdp neighbor" data. This bus link points to an inconsistency in the neighbors on this link (e.g. there is a third neighbor that is not be shown).
