LMS 3.0.1 device discovery issue
jesper_fr
i have problems discovering some switches. The setup is the following:
switch 1 ws-c3750g-12s
switch 2 ws-c3750g-48ts
switch 3 ws-c3750g-48ts
switch 4 ws-c3750g-48ts
The stack T2P2-C2 on the drawing is seed device
the problem is that i only see switches connected to the stack as neighbors, meening that it's not possible to see the connected switches in the discovered table, and it's not possible to get config and upload software.
hope you can help me.
17 Replies 17
Yes, now i can find the missing switches.
I don't know why I only typed in the 10.99.66.10 address. All other networks is typed in with a .* in the end, but anyway thanks a lot for you help :o)
Another "problem" is that after i discovered all devices in the 10.99.66.* network, thay are not added in user_defined_groups in CS.
I have made a filter with this rule text:
Device.ManagementIpAddress contains "10.99.66"
but the only device in the group is the seed device 10.99.66.10. The group update members automatic, but the discovered devices are not there
You should start a new thread for this as grouping doesn't have anything to do with Discovery.
