LMS 3.1.1 : Device Discovery not working
dany.datacraft
I have a LMS 3.1.1 running on Windows 2003 (with Sophos Anti-Virus, no host firewall). Device Discovery on this LMS stopped working on 17 Oct 08. It was working fine previously.
When I Start Discovery, the status goes from Initializing to Stopping. It will show 0 devices discovered.
CSDiscovery.log only shows this generic message:
log4j:WARN No appenders could be found for logger (CTM.common).
log4j:WARN Please initialize the log4j system properly.
2008/10/22 10:00:10 SnmpSocketManager: Shutting down all SNMP sockets.
Io error while closing SnmpSocket : Cannot assign requested address: Datagram send failed
We tried rebooting the server, it doesn't help.
Has anyone encountered this problem before?
Joe Clarke
It looks like you have a typo in your CDP seed settings. Your seed device is preceded with a space. Take the space out in front of your CDP seed, then re-run Discovery. You should start to get some devices.
Hi there,
Thanks a lot. You're spot on. We managed to run discovery after removing the preceeding space.
