LMS 3.1 and CiscoView 6.1.8 not swhowing 10Gb modules
e.bayon
Hi!.
We´ve got a CiscoWorks (LMS 3.1) with CV 6.1.8 and it doesn´t display the new installed 10Gb (X2-10Gb-SR=) modules in the Catlyst 6509E chassis and Catalyst 3750E, what can I do to fix it?
Thanks.
AFROJ AHMAD
Hi ,
Upgarde the LMS to LMS 3.2 and then check the issue..
Download link for LMS 3.2:
https://cisco.mediuscorp.com/market/networkers/productView.se.work?/nxt/rcrs/proieidentity/=17651
Note : you do not need a new liense for LMS 3.2 , your existing license will just work fine
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
