LMS 3.1 - ANIServer Failed to Run
lm_esrome
HI All,
We are using LMS 3.1 and it was working fine . Suddenly ANI Server is failing to run as below.
ANIServerFailed to run0-11073741823N/A9/29/2011 2:02:57 PM
Thought of re intialising ANI database , but still it is not working  . pls assist to solve this issue.
pls find  ani.log & ANIServer.log as attached.
Esrome
6 Replies 6
Svetlana Radzevich
Please check https://supportforums.cisco.com/message/3437996#3437996 the same should fix your problem.
Svetlana
Thanks Svetlana..! i tried this solution, but no luck . Please find ANIServer.properties.orig and ANIServer.properties files after Step 4 :  as attached .
Also , pls find ani.log and ANIServer.log as attached.
Your assistance would be appreciated.
Esrome
ANIServer.properties is corrupted! You do not have a new line after DEVICESROOT= and  DEVICESPACKAGE. This confused ANIServer.
Please only specify value for DEVICESROOT in the ANIServer.properties.orig - you should not delete or enter any new line symbols.
Svetlana
Please find output as below.
C:\Documents and Settings\Administrator.ASTDOMAIN>pdshow ANIServer
        Process= ANIServer
        State  = Failed to run
        Pid    = 0
        RC     = -2
        Signo  = 1073741822
        Start  = N/A
        Stop   = 9/29/2011 4:00:50 PM
        Core   = Not applicable
        Info   = Application failed or was registered incorrectly.
Svetlana
Hi ,
In ANIServer.properties.orig file  I am just replacing " DEVICESROOT=." with "DEVICESROOT=C:\PROGRA~1\CSCOpx\\campus\\lib\\classpath"  . Please find original ANIServer.properties.orig and ANIServer.properties as attached..
Even i tried ,  DEVICESROOT= and  DEVICESPACKAGE in the same line . but no luck .
If you have any working ANIServer.properties file means ,can you please share it with me ,
Esrome
